Wanted FJ60 Manual (15 Viewers)
I have a wiper switch for sale. I can ship it to you for $10. Just tell me one thing, does the 76 have a pigtail coming off it, or does thte harness plug into the top of the switch. I have both.
Josh
I have a set of custom made Alcan springs for a FJ40. They have 4-6" of lift. On a RTI ramp they will stuff a 35"MT on a 8" rim into the front fender without touching the inner fender lip. The rears are a little stiff for a topless cruiser. They were setup for an expedition truck, with lots of gear and weight, you should remove 1 or 2 leaves if you don't plan on carring a lot of weight. I'll ship them to you for $600. I aslo have a set of Warn Black Diamond XT shocks to go along with them. If you want the shocks the price will be $700.
Josh
1987 Bj-70 Windshield Gasket
Hi,
I recently purchased a 1987 BJ-70 (2 door model and B3 engine) I have to replace the windshield gasket and I can't find it anywhere.
PLEASE...can you help me??? :crybaby:
Thanks
Alain
I have a used one is decent shape or get it from the dealer 56121-60120
your in luck sent you PM
I have a good used one from 82fj40. I'm located in Toronto. Let me know if it will work for you. Thx
i'm sure steve has what you need. otherwise, pm me. i have a couple of spares.
A windshield gasket from an fj40 will not work on a bj70 :doh:
dash trim pieces and red brake indicator light for 72FJ40
I am looking for the left lower dash trim piece (no rips or tears), and for the upper dash piece (nice condition).
I also need the red dash indicator light for the hand brake.
Thanks in advance, Claudia
Wanted: 1980 FJ40 Wiring harness pieces
I have a 1980 FJ40 instrument panel that I am putting into an older Cruiser. There was a round wire termination piece and a three prong piece that pressed onto it to give the panel power. I think the years for this are 1976 and newer, but could be mistaken.
I was wondering if anyone had these pieces. I need about at least 6 inches of wire so that I can tie them into my existing wireing harness. But the more wire you have the better. I will pay shipping. Let me know.
Little expensive for what I am wanting.
Thanks though
OEM Heat shield for Cat convertor 2/79 FJ40
This is the piece that goes between the cat and the floor of the tub.
Condition not too terribly important...would like it to be in good shape, but am mainly looking to use as a pattern in an attempt to fabricate a a look alike piece for my renovation.
They seem to be very hard to find!
Thanks!
Dave
so do you need backing plate with cylinders/shoes/hardware? if so, i got a few...you need drums also? i'm in north denver, so close by.
Brett,
Sorry man the one I have must be for a FJ60, it mounts to the right side (drivers). I did not remember which one I had bought for a PS mod.
Josh
Tire lowering pieces?
Need an extension or two plus the crank to lower the spare tire. Willing to buy kit if needed.
