Wanted FJ60 Manual (50 Viewers)
i need it to fit whatever the bolt pattern is in my 60...i'm going to pull the 4.56s out and put them in the 68 and put one of my pairs of 4.11s in the 60.
looking for a front bumper
I met some trees at camp, anyone have one used and in good condition?
Not that I mind feeding Dan's dog, but if I can save a few bucks - that would be great too.
Where are you located? I have one off my 95 that is in decent shape (minus normal rock wear and one small ding).
I just installed my ARB Bar in the front. Any reason why I would want to hold onto it? Has anyone goneback to stock after running ARB?
D
good point...
I am in the Boston area. Any idea what shipping might be?
D
I do not know of anyone who has "reverted" to the stock bumper after it has been culled. Many member have saved them "just in case" there was a future need. Such as in this case where a person is looking to replace a damaged stock bar.
well that sucks.
Junk said:
After 82 posts, you know for sale and wanted belong in the classifieds :flipoff2:
Because the members who have one are not likely to be looking here. :flipoff2:
I could have helped 2 80 owners with this post - me and the lucky recipient of my cash.
IDave,
No, I don't have pictures of this particular setup. The cruisers are up at the farm in Oklahoma. Like I said, it looks really original and fits perfectly on a 71 or earlier FJ40. Really, there's not too much to it. The tank and cap you can still buy new from Toyota. The bracket has been discontinued, so you'll need to source a used on from a parts dealer. The only modification you have to do to your FJ40 is to drill one small hole in your radiator bracket on the passenger side (after correctly positioning the tank braket) to bolt the tank bracket on.
I have a '79 front end, completely rebuilt, 4:11's swapped in, open diff, setup SPOA, new disks, calipers, and rotors, welded double arm. Asking $700 OBO. Also have an SM420 I'd let go for $350 OBO. I'm located just south of Bellingham.
kruisermike@yahoo.com
Mikey
I remember in Hi School one of my buds had a bad ass nova with a 427 in it, we would scrounge up a race and he had to have a assistant to pull the secondarys on the Holley open.....with nylon string.
Butch :doh: :doh:
Ige, I can get them... in both the early pattern and the later FJ40 pattern... but clock it and you can redrill to any pattern...
[/endpimp]
:D
80 series after market rear bumper
I am open to make, Slee, Kaymar, TJM, other known shops, etc. Just thought I do a drag for used befored I ponied up the real money.
Do you know it is still available from the dealer? P/N 38201-60010. About $60 as special order.
Dave
10mm spacers for 80
Wondered if anyone had any 10mm or 5mm OME spacers for 80 series?
I will be installing OME setup this weekend.
Thanks
Harridig
FJ60/62 Tie Rod
Guys and Gals,
Looking for and FJ60/62 Tie Rod, Just need the rod no ends or anything. And if it is slightly bent ect is OK cause i am going to cut it down and sleeve it no matter to make a Drag Link for my steering setup.
Stew
