Wanted FJ60 Manual (22 Viewers)
sent PM
Mike Goodknight said:
How late, what year are the wheels you are trying to use? 93-94 or 95-97 80 wheels or 86-present truck 4runner alloys. this is important. I probably have some call me 970 270 3332
thanks Mike
Specifically it's for the late mid 95 to 97 FJ80 OEM alloys. From my discussion on the boards it would appear the late 4 runner shanks are the same.
azaussie said:
I would like a grey FJ62 drivers (or passenger seat). It needs to be untorn and have good foam. I will pay up to $50 plus shipping depending on quality.
Brown would be OK too as I will use seat covers.
Tailgate for 40
Would like swing out doors but a solid would be just fine ( :
PM me
Thx
I have a passenger seat from a 87' FJ60...i believe the grey pattern on the 87 is the same as the 62's grey pattern. Shoot me a picture of the pattern to jasonsears74@hotmail.com of the pattern your needing. The passenger seat i have is in great shape and the foam is in great shape as well. No tears or rips of any kind.
Jason
Check out liquidoffroad.com for those shackles. Good prices.
jason
Fixed top or removable? There is a difference. If it's removable then buy alum! No worries after that..
PCV hose clamp
I am looking for the little pcv hose clamp that goes on top of the valve cover for a F engine. Thanks a lot.
I know cruiserparts sells the front and rear locked axles for ~$2100 delivered to me (I am in cali) And you could probably sell your axles to re-coup some of the price. Just a thought.
Interior rear view mirror (arm)
Need rear view mirror arm and bracket (can take or leave the mirror itself) for 80 FJ-40. Probably anything 75 or newer would work fine. PM or klrtexx at aol.com Thx!
2 Air Lockers, an ARB compressor, carrier bearings, shipping and installed in your 3rd members should be more around $2000 + or - $200. And alot less work than an axle swap and related wiring. The OEM E-lockers are great, I'm just trying to give you a decent number to work with. :D
hey rachel.
i should have most of that stuff for you, clear out your pm box.
georg
i have one in cali, but that will be expensive to ship.
PKP80 said:
Just as the title says.
Looking to replace my current axles in my 1996 FZj80 with a set with lockers. Trying any means to have the ability to lock up the front and rear diffs. Would love ARB, but 3000 bucks is not too appealing having priced it an axle swap would be significantly cheaper (correct me if I'm wrong).
Considered selling the rig to get a locked 80, but couldn't bring myself to do it.
Sam,
Not that expensive if you are not doing gears. If you just do lockers, and shop around for everything including the compressor, maybe even a used compressor you can probably get away with $1700 in parts. Installing the lockers is time consuming but doable. Or you can yank the pumpkins and pay about $180 per to install lockers. Or you can just install a rear locker which is the easiest and cheapest option.
This is what I paid for ARB parts & install kits only
2 ARBS $700 each price is higher now I think
1 ARB compressor $200 price is higher now
install kit from Cdan $180
ARB lockers install in 3rd member $180 each, probably cheaper because I installed gears.
Down in Hotlanta, GA (where your old front slee resides)
please PM or e-mail me when ya deside to keep the trolls at bay
