Wanted FJ60 Manual (58 Viewers)
79+ steering knuckles.
I am looking for some 79+ steering knuckles for either a Cruiser or a minitruck.
Gathering parts to do a spring over, and I want the wider bolt pattern with larger studs.
Thanks!
-James
Greenville, South Carolina
Links work for me now. Your best bet for the defroster hoses is OEM ($) or simple defroster hose from your local parts place. I used 2.5 defroster hose (carquest #7768-4175) for my '73 40. Came in 6' length and cut to size. Cheap, easy and have been running them for years.
Dom
sc40 said:
i want a carrier and diff, and ring gear (4.11) for a fj-40. it would be even better if it was welded
thanks all
I think I have one of these. Not welded but open. I don't have a matching pinion to go with it, but I can look to se4e if I have it.
How much do you want for it? w/o ring gear
Ring and pinions are supposed to be run together, and not mixed...
If you get stuck all three were still available OEM a year ago. I bought them.
sry i ment w/o the ring and pinion (whitch cannot be found)
make your own defrost ducts and the rubber boot between the housing and the blower tube is part number 87212-60031 iirc
I have a front course spline 4.11 third if your interested. Located in Missouri. You might be able to find one closer though??
I will look. I am not going to be over where my parts are until tomorrow evening around 9pm.
As far as price, I don't know. how about $15 + shipping?
DO you want side gears or empty? I think I have 1 empty carrier, and 1 with the spider/side gears.
However, I think that a full third memeber from Mo might be your better bet.
Cool guys, thanks for the info. Just curious though, what does iirc mean?
4.11 carrier in northeast
Busted my coarse spline 4.11, need a replacement. If fine spline I'll need a driveshaft flange also. Must be complete, all of my guts are hosed save one spider gear. Located in Phila, Pa
I should have coarse pinion third in Connecticut, PM me if you can't find anything closer.
Have 1 spare of that size and brand sitting in Colorado. Well over 95% tread, doubt it was ever used. Zip is 80526 if you want to check on shipping options.
I need a VSV...anyone?
I need a vacuum switch valve for a 10/72 mfg date vehicle. I think 9/71-1/75 will work.
It's the box on the DS fender with 4 vacuum lines going in and out, item 7 in the pic. My vacuum for the distributor advance is not working.
oil pressure sensor/temp sensor/Engine wiring harness for a 1992 FJ-80 LC
Subject pretty much says it. Looking for the following for my lil project.
oil pressure sensor/temp sensor/Engine wiring harness for a 1992 FJ-80 LC 3fe engine.
The harness I need unplugged from the main computer and the main harness. I am basically looking for the starter wires/temp/oil. If the emissions were cut, it would not be a big deal. Also alot of boneyards are lazy and like to just cut the harness at the firewall. That would be fine also. I am mainly looking for the inside plugs that go to the computer and then to the main harness. If anyone has anything like that, please email or pm me.
weigellj@yahoo.com
Thanks
Lee
