Wanted FJ60 Manual (85 Viewers)
The Coin of the Realm in my sty is beer. I'd like two cases of good beer for one F, take another case for an "or so".
If you don't have luck here, you can get them new from Toyota for a bit over $100, they are perfect and painted.
John H
trekker said:
Hi all... need a factory bumper that will fit a FJ 40 '69. Perferably one that is not full of holes from winches, lights and other stuff. I'll email you a FEDEX packing slip. All you need to di is slap it on and ship it off.
THanks!
I have a set of 5 Fj60 rims. Two tires are flat but the rims are in good shape. Wheat Ridge CO....100.00 for all of them.
sent
Stumbaugh,
I paid $125 for the one set that is sitting in the garage last summer but it turned out that I didn't need them. I'd let both sets go for $100 each, however I'll need a little bit of time to get replacement wheels for the ones still on the truck. There are only four in a set.
One option might be a set of four from me and the other set from TreeRootCO since I still sorta need the other set for a little time longer.
Let me know. I am open to negotiation.
FJ40 parts needed
Need some FJ40 stuff to finish off my FJ45, so heres the list. If you can help with anything, shoot an email to:
brettgarland@yahoo.com or
cruiserbrett@hotmail.com
Drivers door 1965-1974 or
Drivers door window regulator- pre 1975
Fan shroud 2F-1975 and newer
Disc brake stock gray wheels(2-3)
F engine Heater Tee/valve in the head
Heater hose Brass "T" at firewall(both)
Heater blower motor(early)
PTO winch shift lever flap on the tranny tunnel
Radiator support rod-radiator frame to firewall(early)
Heater hose support loops/clamps for hose loop over valve cover on firewall
I am sure I will remember more...
Thanks in Advance!
SOR has used ones. I just got one from them, I forgot how much it was but it wasn't too much. My mom threw my old one away by accident after I left it in the trunk of her car :mad: .
4Wheel Parts has them and a bunch of other conferr stuff on their web site e commerce site - just do a search for FJ40. A few days ago, they had new ones for $300.00 ish.
-Stumbaugh
60 clutch/brake pedal pad
I'm in need of a clutch and brake pedal pad. this will be going on an 86 FJ60.
thanks,
mike
order somthin from CCOT and they will send it to ya for free....just ask for it..as the free gift...
Brett, I may have this:
I will confirm tonight, My digi camera has lost the cord going to the computer.
I will let you know.
Warren.
PTO Driveshaft Part Needed
Does anyone out there have one or know where I can get a pillow block housing that holds the bearing of the idler shaft that is between the winch driveshaft and the PTO gear box driveshaft? You can see it on SOR.com under part number 071-72P PTO PILLOW BLK. My e-mail is vhupp@cox.net
Thanks for your help,
Vern
You might want to try GS Cruiser Parts ( http://www.gscruiserparts.com ). They seem to have lots of PTO stuff, most of it seems to be 60/70 Series stuff though. I'd give them a ring anyway to see what they have in stock.
I might have the window regulator.
Anchor Liberty Ale is one of my favorites...
depending on where you live, I've got a drivers door with regulator and glass. also have the "T's"
