I am replacing my stock FJ60 alternator with a “one-wire” unit from Quality Power rated at 140 amps. With the power increase I want to replace most of my main electrical wires under the hood. I have an Optima battery and am running 2 car audio amps off of it. I plan to add LED off-road lighting as well. My car audio wires coming from the battery to the amps are huge (about as thick as my pinky finger, maybe a 2 AWG). The alt to batt wire currently is probably a 10 AWG or so. I want to maximize my charging potential. I was thinking about running a 2 AWG or a 1/0 AWG. Any advice on what gauge to use (about 3 feet)?
I also want to replace my starter wire (about 5 feet). Not sure what size to use for those either.
Also my battery is currently grounded to the AC compressor mount bolt. I do not have another ground straight to the frame or the block. Any recommendations on exactly where I should ground the battery?
Input is much appreciated! Thanks!
