1980 FJ40 4 speed, 2F: I'm replacing the seal between transmission and transfer, and while I was in there to remove the output shaft nut (the same shaft as transmission input - to separate the transfer, the back nut is loose, but staked in place. Anyone have any idea what effect that might have? It's supposed to be 90 ft*lb tight, then staked. Also, everything looks great inside, but I do notice a bit of backlash between input and output (to driveshaft) shafts. Once rolling, seems smooth, but clunking it back and forth by hand, it has to overcome some (slight) resistance before turning. How much backlash is too much? Input and output shafts have a little (guessing .005") radial play. Good? Could be too much by having that nut loose I suppose.
The transmission was tough to get out. After separating, I didn't have much clearance in the back to get the input shaft past the clutch stuff, so I mangled the clips on the fork raising, lowering, side to side trying to find a way to bring it back far enough... I think I have some new clips with my new clutch, but any tips on how to line this up when I put it back in? Get it close, then install the fork / clips once close, then bring it home? THANKS!
