Awesome! Glad all that worked out for you! This is exactly how I test harnesses...
Great idea drawing the wire routing on to the board!
I’ve got the harness in truck but trying to line up everything correctly. Is it just me, or are the welded pliable metal brackets attached to the firewall frustrating to work with?... I think I’m close to the correct orientation but had question about the flasher #8190-30040. The mounting location is on firewall inside by left foot. It requires two 6MM x 1.0 bolts. In order to connect it to where I have the harness, I needed to make a 6” pigtail. Makes me think I do not have harness positioned correctly. Can anyone verify on a 1975 or 1976?
It goes above the computer on my February '75 Federal Spec. It doesn't mount on the tub, but rather that black bracket for the clutch master.
