FJ40 Radiator Extension (Reservoir Runs Out of H2O) (1 Viewer)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
Thanks @flx. Yes, you are correct. The Reservoir begins to get full when the engine gets hotter.
Thats Normal
Thermal Expansion , applies pressure on the RAD cap
at 0.9 it is spec's to the spring will release coolant into the overflow
if your getting more coolant then normal coming out and filling a OEM capacity overflow to max and beyond ?
then I KNOW exactly why this is occurring , there is ONLY one possible reason .
is this your exact or close scenario > going on
73FJ40
After another night of rust removal!
Western Massachusetts
Visit site
To confirm that @ToyotaMatt knows of what he represents regarding FJ40/60/62 reservoir tanks for 2F engines, the following information is from OEM Toyota microfiche, factory service manuals, and volume measurements I performed on a reservoir "tank" in my possession, that was standard on FJ40's from 7501 - 7706:
Here is the parts fiche:
Here is a illustration from the 1975 FJ40 Service manual, available here on 'Mud in the reference section:
Note that the instruction states to fill the reservoir tank up to the "Full" line on the tank, in the cold condition.
Here is an illustration of the reservoir tank represented above with measurements I took using a measuring cup graduated in ml:
So, based upon sound engineering practice and procedures performed by the engineers at Toyota Motors, the design of the reservoir tank may be deduced, as as follows:
Maximum drawdown from "Full" level is less than 1,000 ml. (Primary purpose of full reservoir is to temper the heat from hot coolant entering reservoir from normal expansion)
Maximum expansion (cold to design operating temperature) from "Full" is less than 700 ml.
Expansion beyond the 700 ml design capacity would be the result of abnormal operating conditions allowing "boilover" situation:
- Radiator not designed for A/C condenser heat load and air flow restrictions (OEM A/C systems had larger radiators than non A/C systems)
- Air trapped in cooling system
Overheating due to:
- water pump fan clipped back to avoid interference with A/C compressor
- faulty radiator cap
- restricted/plugged/damaged radiator (internal and/or external)
- improper coolant
- restricted/plugged/fouled engine water jacket or hoses
- corroded water pump impeller
- loose water pump drive belt
- missing/damaged/altered fan shroud
- high ambient temperatures
flx
France
Visit site
do u know the exact capacity you need or want ?
i DO have larger options NOT listed online store ?
I'm happy with it, any bigger reservoir would not fit where I put it and would be a hassle to install.
It's only that the expansion goes from "just above low" to the top in normal operation of my engine but the low level stays stable and the reservoir does not lose coolant once stabilized. And this includes the temperature peak my engine likes to do when you shut it down a bit too quickly after pushing it.
You can see the level before expansion on this picture, and also how it fits to the mm between the shroud and the horn, anything larger would touch one.
But really I was not commenting here to give an opinion on your product, actually before this post I had not mentioned that I was using your reservoir ;)
And yes it's very possible my engine still have some air in and so expands too much, blurping is a never ending task.
Your experience is contrary to what the auto radiator industry manufacturers say .
Possibly radiator caps in France have special characteristics not available here in the US?
Interesting question, because yes and no x)
Yes, in Europe we had a different radiator cap with a release lever on the top (it's pictured and mentioned in the user manual) but this cap is NLA and partnumber completely unknown from the Internet.
So no I'm running the same OEM cap as everyone here.
Actually I have both model ordered from Toyota with the partnumber :
1) with only 1 gasket and listed for <75 :
2) with 2 gaskets and listed for >74, the one already pictured by Matt :
1626838283403-png.2737028
All of that to say that I had noted the conception difference between the 2 but was unable to find what it would change. So when I installed the new cap and then the reservoir I have been very vigilant of how it operated and so I stayed personally in front of my engine with 1) fitted to see the coolant expands and then retracts in the radiator without trouble. Maybe it's not "normal" and maybe once the cap a bit rusty it may stop working but for the time it is.
But yes I'm interested in understanding how it should work and if there is a real advantage to use 2) (because let's be honest, 1) looks a lot better under the hood :playful:)
The important question is, is-it stable ? Does the low and high level in your reservoir always the same ? Does your reservoir lose coolant everytime by the overflow tube ?
And as a lot of people are pointing on overheating, do you have any other sign of overheating ? What does the temp meter says ? Does the engine smells hot ? etc.
Overheating due to:
- improper coolant
This is very interesting thanks !
Sadly I'm not near my FJ40 currently otherwise I would have measured mine for comparison and I will not try to eyeball a value because I know I would be wrong x)
From this picture I see it quite smaller than the original, particularly in width :
And from the picture from FES74 I would guess his reservoir is even smaller.
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
View attachment 2737812View attachment 2737813
the LAST photo here is MY coolant overflow i offer same as i outline above , thats my clients BJ in the photo below with my bottle on his Radatior ,,,,,,,,,,,fyi
thanks
Philippines
Visit site
Thanks @flx. Here are my answers to your questions:
- I don't think so it is.
- No.
- It depends on how far I travel. If it is an hour trip, then YES, expect an empty reservoir the following morning when you check it.
- If the traffic is heavy and no movement for 15 minutes or more then i see the temp meter going up. So what i normally do is I try to pre-empt the Rad not to overheat by stopping the engine at the side of the road. But so far i have not seen it overheating yet. Just symptoms of overheating.
- Temp meter is consistent at the middle as lonh as it is running the whole time.... meaning w/o heavy traffic on the streets.
- Yes. It is a bit hot. I need to use a cloth rags to touch the hood and open it.
Thanks @flx.
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
i have a OEM Radiator cap with a manual arm on it to relive pressure
is this what you refer to above ?
its a NON USA Toyota parts application for a land cruiser , buts that's all i know about this unique radiator cap manual arm on top ?
Carson City, Nevada
Visit site
Im sure someone has already said this but just in case I'll mention it. For every 1 pound of pressure in your cooling system, it raises the boiling point 3 degrees (F). So if your system has a 15 pound cap, the boiling point would be 257 degrees F. If you have a cap that wont seal, water will boil near the normal 212 degrees. Replacing the cap is probably the easiest and cheapest way to go to see if it fixes the problem.
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
YOU CANNOT Exceed the 0.9 pressure spec. on the OEM toyota land cruiser cap genuine nippondenso ..........
fyi thats a recipe for a major issue ...
see photo below of the cap ear tab ...........
ALL 5 different style caps below are for Land Cruisers various years applications
big cap pre -4/86
later small cap 5/86 and later
ALL have 0.9 pressure specs in fact i have NEVER seen any Toyota that had a different pressure cooling system spec ..?
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
Overheating due to:
- improper coolant
well ?
was i right or ............ 🤔
i have a fj60/62 new overflow coolant bottle
i filled with water and then poured into my compact tall and skinny bottle i offer shown above
same exact capacity ............
it is indeed a optical illusion that it appears small maybe , but that's its true gift to 40 series and 55 folks too
it is approx. the same OD oe thickness as the radiator support frame itself ..........
so its both protected and non interference designed .........
i nicked named it my " KILLER KOOL LITTLE GUY "
and he indeed is just that :cool:
Philippines
Visit site
Noted @Magnum44 . Thanks.
Philippines
Visit site
Thanks @ToyotaMatt . Yes. I bought that unique cap from Rockauto parts. It is made from Mexico.
ToyotaMatt
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
None yet. I sourced out most of my FJ parts from Rockauto parts, eBay and Partsgeek.
I Offer ALL First Time MUD MEMBER Customers a special 10% off coupon Code ...fyi :cool:
i will send you a PM to further discuss ....
here are the LINKS for both your Needed Genuine NipponDenso Made In JAPAN Land Cruiser Parts .......
Philippines
Visit site
Thanks @ToyotaMatt . Truly appreciate this.
