FJ40 2.5 " lift and 32 " tires
Discussion in '40- & 55-Series Tech' started by mep1811, Jul 5, 2005.
  1. mep1811
    mep1811
    1,251
    151
    Jan 11, 2003
    El Paso, Texas
    Anyone running a 2.5 lift wioth 32.11.50.15 tires? I think I have decided on a 2.5 lift and was wondering if 32 " tires fit well without rubbing?
    I am thinking of the BDS lift.
    Thanks Mike El Paso TLCA 8009
  2. Yoda
    Yoda
    400
    Feb 23, 2002
    North Bend, WA
    I'm running 33X9.50 with add-a-leafs on stock springs. My rear fenders were already cut with flares, so I don't know if they would rub stock fenders.
  3. e rock
    e rock
    1,622
    16
    Feb 24, 2004
    Monroe, WA
    Short answer: probably fine.
    Slightly longer: I have a 2.5" lift with a bit longer shackles in the rear to account for sag. The bumpstops are in their stock locations. I used to run 32x11.50s on 15x7" rims with 3.5" of backspacing. The tires tucked nicely inside the rear fenders, but would rub on the inner fenderwell when fully crossed up. Not a big deal to me, but it might be to you.
    I currently run 33x12.50s on 15x8 rims with 3.25" of backspacing and I have a 2.5" lift with a bit longer shackles in the rear to account for sag. I have trimmed my rear fenders as well. No more rubbing. The wider rims with less backspacing moved the tires outboard enough to alleviate the fenderwell rubbing.
  4. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    should work fine, and take you everywhere you should go...
  5. e rock
    e rock
    1,622
    16
    Feb 24, 2004
    Monroe, WA
    After re-reading.... What kinda cruiser? Your 60? Try re-posting over in 60/62 Tech.
    The URLs in your sig don't seem to work either.
  6. Bodean
    Bodean Hot Damn SILVER Star
    11,429
    Media:
    18
    Albums:
    1
    3,184
    Dec 20, 2004
    Brandon, MS
    Speaking from experience, go woth the 4" lift. No more money and I promise you will wish someday that you had more lift. I have been through the 2.5" with longer shackels and 33x10.5 swampers stage only to want 35's. Just my .02.
    Later,
  7. mep1811
    mep1811
    1,251
    151
    Jan 11, 2003
    El Paso, Texas
    FJ40 2.5 lift 32 11.50 tires
    Thanks for the information. I have added a 1977 FJ60 to my fleet of two crusiers. My wife will be driving this around town mostly and I will take it out to the rocks or off road on the weekends. Since everything is so far from El Paso I would like a suspension that will not beat us up too bad on the highway.
    1985 FJ-60
    1977 FJ-40
  8. 2badfjs
    2badfjs
    5,522
    4
    Jan 26, 2005
    in the garage
    33x12.5 on a 10" rim
    1/4 inch spacer
    2 1/2 skyjacker springs
    NO PROBLEMS! :D
  9. bonzai
    bonzai
    341
    Jun 28, 2005
    Colorado springs
    Nice....Is their a lot of body roll going around the corners?
  10. e-man
    e-man
    143
    2
    Mar 28, 2005
    Fort Worth
    I think I have a 2.5" lift and I am running 33x12.50 on 2.75" backspaced rims.
    At FULL flex (which is an impressive amount) I catch the front fender a bit.
  11. Lovey
    Lovey Oct 2004
    393
    11
    Oct 30, 2004
    I have 2.5 springs w/ shackles and 32x11.5x15.
    No rubbing problems here.
  12. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    lol
    Okay kemper.
  13. Poser
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    Hey man...
    I have hair and tires!!!
    funny thing was that russert said this out at my shop one night, before he built his wheeler...about 33's....I have laughed about that many, many times..
    :beer:
  14. Poser
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    pretty rare find there mike...
    :beer:
