Hi everyone. I am trying to remove my flywheel housing so as to replace my clutch disc and pressure plate. I have the transmission removed and the flywheel under housing (pan) removed. The two top bolts on the flywheel housing have been removed but there seems to be other bolts that I can't see or access. I suspect there may a dowel or two between the flywheel housing and the engine, but I suspect there are bolts I can't see or locate?
Thanks for any direction / help.
John
John
