FJ Cruiser Pricing Question (1 Viewer)
So this unit plugs into the OBD-II port?
Fully plug and play using maestro for steering controls and idatalink
everyrhing on steering controls works just like OEM
I get all the vehicle data - range/mpg and trans temp are what I use most. You can configure to much more data.
I get an additional rear camera display thats 7 inch in addition to the mini one in the rear view mirror
easiest install ever and best money I spent on “mod” as far as usability for my needs
I don't know exactly what that means (data interlink btw head and car's ECU I guess). I don't have steering wheel controls, so not worried about that. I have a Pioneer AVH-1440NEX headunit. I'm more curious about the data from the ECU and possibility of ditching the ScanGaugeII that I have. Does your headunit have the engine data app natively or its something you installed on your iPhone?
:banghead:Yes, I know how search works. I perused all their products for my vehicle. That site show products without explicitly stating what they do - if you are a professional A/V installer, it might mean something to you. I'm no electronics expert, so this ** is just a bunch of jargon. You guys aren't helping much by throwing links at me. I'm asking specific questions about @ryanCA 's installation, like how did you get engine data on your screen?
"The industry standard 'all-in-one' CAN interface module. Web-programmable for over 4000 vehicles 1997 to date including exclusive KLON firmware applications. Features single-wire connection to popular aftermarket remote start, vehicle security and convenience products equipped with an 'iDatalink' or 'DBI' serial port. The original member of the iData™ family. "
"Universal 'all-in-one' integration cartridge. Web-programmable data immobilizer bypass and doorlock integration for over 4000 vehicle models from 1997 to date including exclusive KLON firmware applications. Inserts directly in Blade-compatible remote start, vehicle security and convenience products for seamless integration."
Series:iDatastart HCiDatastart HCiDatalink BypassiDatalink BLADE
Vehicle make count:45454242
Vehicle model count:925192511017110170
Vehicle years:1988 ~ 20201988 ~ 20201988 ~ 20201988 ~ 2020
FirmwareRST-TLKRST-TLKTB-TLTB-TL
KLONNot ApplicableNot ApplicableNot ApplicableNot Applicable
Keys for Programming1 Key1 Key1 Key1 Key
Keys for InstallNoneNoneNoneNone
STANDARD
Downloadable Software
Serial Data Communication
2-Way Serial Data Communication
Feature Selection
Programming Menu V3
REMOTE START
Immobilizer Bypass - No Key Required
What you see in screens, nothing is from phone. All came "natively" as you said on the headunit. I plugged the head unit in the back. And walah, all data live.
I know 0 about electronics. I can do mechanical things all day long. I walked into best buy, bought the Pioneer, idatalink, maestro. Thats what hte guy told me I needed. Came home, spent 2 hours (first time in my life doing any audio work), installing it. Followed the how to. Plug and play meaning, I took the plugs and pluged into the other plugs that went into the old OEM head unit. No wiring, no splicing. As I don't know how to do those things with confidence.
I just wanted:
  • navigation
  • carplay/android auto
  • Everything wireless
  • My steering controls all had to work as OEM
  • My bluetooth work as OEM
I didn't want like most aftermarket setups people have, horns don't work, bluetooth doesn't work, steering control doesn't work. When I explained to the guy, he told me the 3 things I needed (which I listed). I don't even listen to music. 90% of the features are lost on me.
I love the 7 inch backup screen. While playing with the unit, I found that it picks up all the things from the car's system, to show me. I tow my sand toys to the desert, havign the trans temp is handy.
Thats all I got buddy.
I just wanted:
  • navigation
Thanks, this is very helpful.
An ozone generator does a fair job removing the smoke odor from everything, even what's hidden behind panels. But a good generator (5000mg) used for a full day or longer. And it may require treatments every month or two. Each treatment oxidizes the top layer of tar... once the stuff underneath soaks back out, another treatment...
I read up on this and lots of studies from several sources including EPA. They claim it is ineffective.
Do you have personal experience with these?
Found one on Amazon for $85
I learned the trick from a car rental company. And it has worked for me.
I've successfully used an ozone generator to remove smoke and odors from cars. It's not 100% - the odors will come back as the oils weep back to the surfaces - but it really does help. But you can't do 5 minutes and call it good - you need to ozone for hours. Last car I did was a Subaru my SO bought -- used by a guy who drove it for work for 10 years -- he never was without a cigarette. Vacuumed out all the dust I could, shampooed the upholstery, dehumidified for about 48 hours to dry everything: then ozoned another 24 hours. It didn't smell bad when I was done. But needed another treatment a few months later. And I am ultra sensitive to third hand smoke.
My recipe: I closed all the windows, left the generator inside, turned it on continuous, and walked away. Next day turned it off, opened all the windows and let it air a couple hours.
That said, ymmv.
ps: I own these two models: the smaller unit was used on the Subaru
www.amazon.com/gp/product/B07D8MC68M
www.amazon.com/gp/product/B00LUY15D6
For $85 I might try it as I also have some apartments I rent and occasionally I have to get rid of Pet Odor, Cigarette Smoke and recently Curry.
I love some Indian food, but Geez that smell will NOT dissipate!
