Hi all, still working on this idle problem. Currently have a new pcv valve and fuel filter. This helped a little bit. I am running a can of sea foam thru the system right now.
I think there is some condensation on the tank from it sitting so long and never being used.
Anyways so on a cold start it runs fine, after warm up it idles around the 600-700 mark and is very rough.
So this morning I got desperate and disconnected the ISC and started her up. The engine was cold. It idles fast, as do all my other toyotas when you start them cold. About 2000 rpm, I think that is a little on the high sdie, but if it will do no damage I am fine with it. After playing with the idle adj screw I got it down a little and I took it for a nice long drive, subjecting it to some freeway and stop and go and its amazing that it does not ever go into its finiky idle thing. Keep in mind that the isc is just disconnected. I hooked it back up and started it and it ran like s***.
I think I have narrowed down the problem here, do these isc things ever cause problems for you guys?
I have been looking far and wide for mechanical problems, is it possible that its just this elec sensor?
It never made any sense, toyotas arnt supposted to have mechanical problems at 132,500 miles.
After my engine is warm, I idel in neutral at 1200 and while stopped in drive at 800.
any suggestions?
thanks -nate-
any suggestions?
thanks -nate-
