I am sure there are already 10 threads on how to do a lift on a Fj-60, but I thought I would throw mine out there into the "search" fodder.
I recently purchased a 1984 Fj-60. It spent 20 years in Colorado so the body is decent but the back 1/3 of the underside is fairly rusty.
I have been out of Cruisers for a while playing with buggy's so this is the first leaf spring suspension I have installed in about 6 years. Of the 10+ Cruisers I have owned and modified it is the first Old Man Emu suspension I have installed.
The following is a list of tips that I felt like I should share for those that plan on installing an Old Man Emu OME suspension in their FJ-60 / 62.
3 weeks ago I knew the suspension install was eminent, so tip #1 is:
Before installation, thoroughly soak any and every part that is going to be removed with penetrating oil such as Break Free. I hosed every bolt and nut 3 times in 3 weeks.
top 10 tools you WILL need for this install, don't start without them.
1) 4 quality jackstands
2) Floor Jack
3) Heat source - cutting torch or propane torch
4) 5# and 12# sledge hammers
5) Air chisel (optional, but nice to have)
6) rubber mallet
7) 10, 12, 14, 15, 17, 19, 21mm sockets, (deep)
8) 3' breaker bar
9) Impact wrench
10) Sawzall
Wow, that is a lot of crap to collect just to do a suspension lift....well, if your 60 series is like mine, the stuff you are about to remove has been on the vehicle for anywhere from 19 to 28 years. Stuff gets "baked" on when its been on a car for 20 years.
Here is the start......
2) Floor Jack
6) rubber mallet
8) 3' breaker bar
9) Impact wrench
10) Sawzall
