OK, Jack, it is now officially September........we need more. Many of us are living vicariously through your build
Have you had the driveshafts made yet?
Ed
Ed
jackbrad said:Things went sorta slow this weekend...
After doing that the transfer case and rear diff lined up fine, so I moved on to the motor mounts.
I started by heading to Napa to pickup a couple motor mounts that would fit the block.
They were pretty cool and only 8-9 bucks a piece.
http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=6021107&Description=Motor+Mount+-+Front
Then I went back to shop... with the engine in place and the trans set right... we had everything ready to make the motor mounts.
I took a 1/4 piece of plate and made scab plates for the frame. The we cut a 2x4 piece of square tubing and cut two diagonal pieces out of it. The just took a thick tubing pipe and cut them to fit.
Here is a pick of the pieces.
Welll then we just stuck them in with clamps and tacked them together. My brother Pete made it easy by doing all the crawling. We did not feel comfortable putting the car on the lift the engine etc.. hanging out of it.
Pete went ahead and welded them together while I cut some old ones off the frame and cleaned it up for welding...
More...
