- Thread starter
- #21
Choke Opener:
If you can’t find a used one, just plug the broken nozzle with something that will take the heat (bolt?) and install it all the way at the back. Plug the air rail nozzle too that mates to it. It’s invisible back there under the air cleaner. Can’t be seen.Need one of these air rail unions. Appears I twisted one off in the removal phase 5 years ago
Thanks for the feedback @OSS I trust your opinion a lot. So I think what I’ll do is put the blocking plug back in number 6, that was in during the desmog (farthest back) and since I can’t use the air rail on 6 due to the union being broken off inside the nut, I’ll cut it off just behind the nut and fold over the small pipe nozzle then solder or braze it closed. I’ll let you know how my emission goes after that.If you can’t find a used one, just plug the broken nozzle with something that will take the heat (bolt?) and install it all the way at the back. Plug the air rail nozzle too that mates to it. It’s invisible back there under the air cleaner. Can’t be seen.
I inadvertently twisted off my air injection nozzle on the ai mainifold that mated to mine on #6 but luckily it was a clean twist and air tight. Didn’t leak. I didn’t have a functioning 6 air injection nozzle for 20 years and the cruiser passed CA smog tests every time. Easily.
I got a nice air rail I’d sell. I took it down to bare metal and clear coated it. All fittings are good. No check valve though.Cut and pinched #6. I think it’s going to be good enough. I’m using my original that had the broken off nozzle embedded in #6 not the rail that I bought for backup and then twisted apart. View attachment 3258999View attachment 3259000View attachment 3259001
