Finally extended my breathers
The nipple in the rear axle where the breather hose attaches is "loose". I can rotate it. Is this normal? Should this be a tight fit?
Great thread!
Thanks
good write up, one of the first things I did to mine a few years back
Following up on this - the stock breathers are designed with 'one-way' caps pressure can be released, but fluid shouldn't be able to make its way in.
My breathers seized, causing the rear diff seal to blow out, so I replaced front and rear diff breathers. The tcase/trans appear to use a different part# for breather (so I believe I now have 2 extra breathers that are only good for front/rear diff).
Question - am I correct that the stock breathers should keep out fluid even if submerged? it appears pressure from the diff allows air to vent out, but the ball/cap/rod would seal if fluid tries to get in?
When my driver side rear axle seal started to weep gear oil, I checked that too but that wasn't the case for my 06Lx. But yes the factory 10-inch rear diff breather hose has a one-way valve cap to allow higher pressure from hot/warm gear oil to vent out but keep water from going in the differential. And if you are extending it (using a longer hose) all the way up to the highest part of the engine bay firewall I think it's safe to say to use a 2-way cap/filter head since it's already almost a meter high from the ground.
Here is some anecdotal information. I have an old '85 Ford for hauling lumber and firewood etc. It started pushing 90W up through the speedo cable. I discovered the transfer case breather was totally clogged. I cleared it and it solved the messy problem. Similarly, the rear diff cover was leaking and I was perplexed as I had recently resealed it. Again it too had a major clog in the vent. I actually had to removed the vent tube and drill out the mess. The problem again was solved.
Lastly, I have heard that a hot case can actually actively pull water inside when submerged. While I do not know if that is true and I am not too familiar with hydrodynamics, it seems extended breathers for our most adventurous of trucks remains wise insurance to prevent continuous replacement of fluid.
Did mine this afternoon
Glad I did, as you can see the hose is split and front diff will no doubt ingest water if I was to wade in a river or flooded road. But, fair warning to those who are looking to get it done, the front diff is a huge PITA.
Here is my contribution to this thread:
How-to guide for installing differential, transmission, and transfer case breathers on your 2006 100 Series Land Cruiser.
Nice job. I have been running that breather kit for about a year. I like it.
