Filling door panel holes - how? (1 Viewer)
kcjaz
Olathe, KS
So I've ordered a set of Rhinohide Armor panels and they will not work with the stock lower door trim panels. My options are trim the Rhinohide panels or pull the OEM lower trim panels off. If I do the later, I'll be looking at this:
So how to best fill the holes? There is no easy access to the back of the holes without removing the door skin. I don't have the skills to do this myself and at that point, paying someone to go that far would likely be cost prohibitive. I'll likely leave the Rhinohide panels on most of the time so I've thought about just covering the holes with some kind of tape or a wrap strip. Not sure I could make that look ok with out the Rhino panels. Anyone got ideas?
Something like these hole plugs (On Amazon: Auto Body Hole PLugs) might be a good temporary solution until a better one presents itself:
HTH
It depends on what you plan to do with the truck in the future. It may hurt the resale value.
If you are thinking about it, then the plugs ^ is a good solution. If you want to do it properly a body shop should be involved to weld the holes, repaint the panels, and blend with the fenders - not cheap and it looks like you are not willing to spend the money anyway.
If looks are not important, you can cover the holes with vinyl wrapping or similar.
I don't really care about resale. I'm willing to spend some money on this to make it look like the HE w/o the lower trim but probably not >$1000. I think the plastic plug idea is where I'll start and see if I ever really remove the Rhino panels.
just wrap the lowers where the holes are, in a close to body color.
That will keep water out and it will look ok, with a close enough color match.
I doubt the rhino hide will come off much, right?
