I'm just about through all of the disassembly for the timing belt replacement on my 03 LX470. I'm kind of stuck on the A/C compressor being in the way of the fan bracket.
I've seen this picture which looks like if you remove the front 2 bolts of the compressor, the fan bracket comes out.
My problem is there is a stud that pretty much keeps that bracket from moving around the bracket and electrical connector (even if the bracket is bent)
What am I missing to get this thing off?
I've read about loosening the rear A/C compressor bolt but I absolutely cannot figure out how to get a socket on there and actually loosen the thing.
Should I be focusing more on removing the bracket atop the compressor?
Something else?
Thanks!
Something else?
Thanks!
