- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,523
Bump !! - this thread needs attention
on previous pic of my belts did the PO not get the correct belt because it does not go to that third point at the WP?
thx for quick answer
So ! ,
Lookie lookie , lookie what we have here ..................
One of My all time Favorite Uses of :
Alternative Toyota Genuine Parts Engineering Mindset Approach Applications ,
and a Killer Kool one at That !
its a 83/08 - 87/08 AL25LG-ZWFDCA attempted Pump Install / Conversion / Update
- from what i can see from @Kschep 's Photos Posted above , we have a Slightly miss-installed
/ miss-alighned 1985 AL25 Tercel 4x4 Wagon Power Steering Pump Conversion Update ,
- a bit sloppy install by the PO , but we should be able to make quick work of the needed corrections
prior to @Kschep going to his Local TOYOTA Dealership parts Dept. , & simply ordering
the Correct Size needed OEM parts maker Mitsubishi BANDO , V-Belt necessary to make it all happen
for him ...........
- Step #1 remove the old drive belt , DO NOT CUT it OFF !
- Step #2 , Remove pulley on Pump and simply Flip it over and Re-install backwards
- step #3 Loosen the Existing Landcruiser smog pump bracket Under the Moter Mount Dog Leg and ,
Further Align the AL25 Pump Pulley Groove By Eye to the FJ40 inner crank Pulley Groove
- Step #4 Order the correct OEM TOYOTA Drive belt , using the Belt Chart on Various parts Microfiche
- If your Local Dealer parts Dept. Counter Person has No Clue , then use Static paricute Cord ,
and Obtain the Needed Belt Diameter Yourself ,
- Find Your Local BANDO Aftermarket Drive Belt Dealer , and Buy the Closest possible size in-stock
- DO NOT Buy any other Brand Drive Belt , especially and For example :
the RUBBISH Elclin Line @ NAPA , if you do skimp on this step you will Be Sorry very soon
- Install Correct size BANDO Belt , adjust Belt tension to FSM Spec's , test fire 2F engine in place
for a few seconds , turn off , Re-check belt tension , Readjust as necessary
- If your Pully's are still slightly miss-alighned , but Not and should Not be Cock-Eyed at this
point ? , add shims / washers to the Pump Pivot Bolt as needed to bring pulley faces back and
forth to perfect harmony and Plumb , level , & Square type Mindset to each other ...............
- I have preformed and installed this TEq needed Creative Solutions Parts Update Many times in my life
to both my own Trucks and My shop client's as well , its Time Tested and pretty much Bomb Proof
Im my opinion
- i keep 3-4 Complete Conversion Kits on hand at all times , because you never know when
the need for one will arise ,
- The whole idea here , i should have mentioned before step # 1 , is for Pre- 1/79 2F 's with out the
3 Pre-Drilled / Threaded Cylinder head Pump Bracket Mounting holes above on Driver Side
Engine Flat Spot , to have the Same GOD givin right to have the closest thing to a OEM Optional
Power Steering System as possible , while incorporation of a MINI Truck Power Box as well
for a Symphony of JDM engineering End Product Results .....................IMO
- theirs a bit more Trade-Kraft to the conversion then my Ramble-On above Mentions to be clear
, but my Focus was on the Needed Corrections for @Kschep to get him back up and Running based on
my past experience with this big Picture , and everything and anything i could Conclude ? from his
Very Well Documented and Clear Crisp Photos he Posted .......................
i hope this helps ........
also , maybe @4Cruisers has some additional input here , as he taught me most everything
i needed to know , shared Photos's , to make a go of my first Conversion so long ago it seams
Thanks Brother !
kindly matt
