- Thread starter
- #1,341
Update cont.
The next day we took care of some family stuff all morning so I got outside in the afternoon. The paint didn't look half bad but it needed another light coat to finish it off so I broke out another can and finished it off. Once dry enough (didn't take very long) I started putting on the accessories and pullies. I wasted some time trying to clean up the alternator housing. I then got the bright idea to tap the lower support tab so I wouldn't have to fiddle around with getting a nut on the back side whenever I take the alternator out while in the truck. The threads were a little shallow but it torqued down fine. I didn't drill the hole, just ran a tap in the existing hole.
I had to run to the store to get a couple things. I needed a new o-ring for the block heater. This one fit well in the store but I'm not positive it has enough meat to seal it up.
I also needed new washers for some fuel parts. None came in the rebuild kit.
I cleaned up the engine mounts and bolted those on. Now on to some rebuilt and painted engine porn pics:
This side was never painted but I took the opportunity with the tranny adapter off.
Next came the adapter and that meant picking it with the engine hoist. The engine stand came off and then I cleaned up the adapter. It was pretty filthy but a can of oven cleaner gave me a hand. Once I finished cleaning up the bolts they all got red locktite and were torqued to spec. I put a light coat on the flywheel to keep the rust away and once it dried I got out the red locktite again and torqued those bolts down. With it dangling on the hoist I needed the
to come out and give me a hand to keep it stable and to keep the crank from rotating as I torqued those down to 101 ft lbs. I marked the T.converter and the flywheel with white paint so I could line it up the same on install. I just transferred it over after the cummins beige dried.
Just for giggles I counted the teeth and wrote it on the flywheel. I also wrote on the back of the head and block the rebuild date and that standard sizing was used.
It was getting late but I thought I could set it in the engine bay right after I removed this broken tranny bolt. It proved to be more stubborn than I and I gave up for the night. I used heat but maybe not enough so I'll give it another round next time.
I cleaned up my mess and used the ol' tire cushion for the engine. Dora should be on the road next week.
