I have a 74 FJ40 1.5 with a bad #6 piston. The engine can be rebuilt but for about the same money I can buy a professionally rebuilt 2f with Toyota parts. I am not certain which way I want to go but have a few questions if I convert to a 2f.
1. I see where some people have retained the F intake manifold and carb. Will this sacrifice performance and does the F carb need to be re-jetted to work properly with the 2F?
2. Other than changing the flywheel and clutch, what is involved in converting to the 2F clutch i.e. linkage, slave cylinder etc? Is it worth the upgrade?
3. Any problem retaining the F water pump and crank pulley?
