I'm going to build an exterior staircase to a 2nd story room on my garage soon. I'm not sure which is better between building the landing and then the staircase being attached to the side of the building or leaving it off about 2 or 3".
Either way the landing will be supported by two columns and there will be a concrete pad where it starts at the bottom. I think it will be fairly sturdy either way. I plan to cut 2x12 stringers for construction.
So... should I attach it to the structure or not? If I do build it attached to the building, I assume I would install before siding. Siding will be vertical board and batten - faux board and batten with 4x8 sheets of hardie panel and battens placed on 16" centers if that matters.
