Exhaust Recommendation
How are you connecting the scanner to the ECM?
I am using the diagnostic port under the hood.
MT2500 is an old Snap-On OBDI scanner, he might have the Toyota plug and chip (they used little game cartridge looking things containing the definitions for the manufacturer) for it actually, which is fairly rare. You can also measure and graph the O2 voltage response from the Diag port in the engine bay as well.
Just as an FYI the Snap On MT2500 works on OBD2 cars and trucks too. Snap ON supported the MT2500 up till the 2008 model year with software updates that could be reprogrammed on the tool truck on a new style RAM cartridge that Snap On offered in the early 2000's.
With that new RAM cartridge you could update all the different manufacturers info for the upcoming year onto one cartridge without having to buy a different cartridge for each and every car manufacturer.
So you have a SnapOn connector for the DLC1?
Well that's pretty damn neat, if I didn't have an Autel I'd try to hunt one of those cartridges down for my MT2500. I don't have the Toyota DLC1 connector or cart for it, I just keep it around for old Ford and GM garbage that rolls through the shop. I still want an MT2400 DMM though, been trying to find a working one for a few years. I bought a TOYOBDI a few years ago for checking on the Toyotas. Honestly doesn't come in use much these days, most folks come to us to install standalones and get rid of the stock computers anyway.
LX450 with super charger, CX Racing headers and 3" custom over the frame exhaust. J-pipe to reduce the drone at 2800rpm/75mph. 4.88 gears and 35" tires.
Sound clip with spectrograph:
The shop had to cut and re-weld cylinder #2 pie to clear the supercharger body.
The J-pipe is the 2" dead end section that points to the driver's side. Muffler ahead of the rear axle and two resonator's behind.
LX450 with super charger, CX Racing headers and 3" custom over the frame exhaust. J-pipe to reduce the drone at 2700rpm/75mph. 4.88 gears and 35" tires.
View attachment 4054044View attachment 4054046
Small world I also had my exhaust reworked at Scottsdale muffler on my 80 back in the day. Any idea what the length and diameter of your helmholtz resonator is (j-pipe thing)?
**These headers block the EGR port at the block**
This is the schematic with some part numbers as a starting point. Diameter of the J-pipe is 2".
The table at the lower left are my estimates for the length of the J-pipe, which was 24" to 27". The clamp allows for some adjustment, but they set it at 25.5" and it is sweet! They asked me to come back and have it welded once I was happy with the sound, but it has been 9 years and I never went back.
The formula is based on the air temperature inside the dead end tube as this determines the speed of sound for the reflected 1/4 wave.
Crushed as flat as a pancake at the rear diff!
This is my 3" at the rear diff. Lost a little cross section area due to the bends, but still pretty good.
To answer your question, yes, my scanner came with a connector that plugs right into the DLC. No need for paper clips or jumpers to read my trucks trouble codes.
Looks well made.
Can't help but see this straight shot to the bottom of the exhaust manifolds
If you don't want/ need cats, this is way nicer path than up/down/looped around the frame path toyota
He’s got a weird muffler upstream that dumps it into the passenger fender well…
Find a competent local hot rod fabricator or exhaust shop and have them do a custom setup.
I've installed a "Brexhaust" setup (Magnaflow) for a friend, and it failed within 6 months. They have warranted it, which is great...but now I gotta do the work again. It was a direct bolt-in setup, and was pretty cheap...
I'm putting a turbo on my truck next week, and the exhaust from the downpipe back will be custom fabricated stainless steel, with v-band clamps and nice hangers to make it easy to service.
I puchased the Magnaflow header+cat and the second cat and had an independent shop put them on 8 years ago and they are still going strong. So, YMMV.
