About twoish years ago I had a muffler shop weld up a new cat-back muffler/tailpipe. Friendly service, no issues. Fast forward a bit, I found that when the rear driver tire stuffs into the wheel well on the trail it bangs into the tailpipe going over the rear leaf and breaks the rear exhaust hanger. I also added a 4x4labs rear end to the truck since the cat-back was installed, and want to scoot the tailpipe over to exit under the driver's quarter. I picked up some exhaust ends to clamp/glue on the end of the tailpipe, thinking I'd cut it back near the mudflap and install the end. I've since moved states and can't use that shop any longer, so here are my questions....
1.) Spot where the tire rubs, any ideas on how to fix this? Heat up this section/dent it in with a hammer?
2.) Can I run the exhaust without using the rear-most exhaust hanger? The next nearest hanger is the one behind the muffler:
Exhaust as it sits now, i'd like to move it over under the driver's quarter to avoid the eventual squish when the backend drags:
I'm thinking a muffler shop would probably chop off this tailpipe and bend a new one, but I'd like to pick Mud's brain before going that route... thanks fellas.
