Coolant level must be verified in the actual radiator. it should be up to the neck when cold.
The overflow tank does not show coolant level in the system. It holds coolant that has exceeded system capacity at some time in the past.
1. Park with front slightly uphill if possible
2. Fill radiator with Toyota or Zerex Aisan red coolant
3. Start engine and turn on heaters, front & rear if you have it
4. When engine reaches operating temp the thermostat will open and likely suck coolant from radiator into system
5. refill radiator as needed as coolant gets sucked into engine
6. when heaters are blowing hot and radiator can't take any more fluid, install cap, turn off engine, and let cool. Fluid will likely overflow into bottle as it cools.
