Aerial not responding to up/down button
UK
Hi folks,
As above, my 100 series aerial goes up and down fine with ignition. The button on the dash activates the relay (you can hear it clicking when pressed) but the aerial doesn't attempt to move or make any other noises.
It's causing me issues because I have to park in underground car parks and the aerial hits the barrier so I've got to do some crazy manoeuvres every time.
I'm at a loss what to check, any suggestions?
Thanks!
Any thoughts from anyone on this? Thanks
If it's working with the ignition then it has power, and if you're hearing the relay with the switch, I'd check the wiring between the relay and antenna motor.
Thank you for this, now you explain it like this it makes sense! I'll report back.
