Engine shuts down randomly
Denver, CO
Hey guys,
My brothers 1999 100 series randomly shuts down when in drive. It happens in High and Low range. When stopped in traffic, on a trail, or most recently just when you let off the throttle on the highway (current location). CEL and A/T OIL TEMP come on, and the red battery in the left corner. When it happens, rpms drop to nothing and throttle is no good. Seems to happen between 2000-0 rpms. Throttle does seems to have a more delayed response than what feels Normal for a car or at least my 80.
Car starts up after ten or so minutes
Codes thrown are - PO75 - Input/ turbine speed Sensor A
and previously a fuel mixture too lean code
Please help.
I'd also check for pending codes, throttle response if it's all or none sounds like a coil pack.
Fuel system vapor lock? My 100has done it a few times in hot weather.
Assuming battery is good, I would troubleshoot the coils and spark plugs first based from the symptom and DTC you shared. Check for burnt mark on the spark plugs, that should give you a tell tale if the coil is due for replacement.
