EDIT We are talking a 74 here, right? That's different fusible links.. My bad.
Hi
Sounds like fusible link line 'A' blown.
The fusible links are connected to the battery at one end, and to the harness on the other end. By factory default, the connection to the harness is either a plug&socket connector (round) or eyelets on a bolted connector in a plastic box (depends on which link it is; I think Line A is the round plug&socket, but not sure. Go by wire colors).
You can check the fusible links by measuring voltage at the connector to the harness. No voltage there: Fusible link blown.
The factory fusable links are color-coded Y yellow (1.0,) L blue (2.0) or B black (1.25) and connect to the harness like this:
Yellow to white (Line A, your suspect),
Blue or Black to black (Line B, C, also feeding all other main lines trough the ignition switch).
(I only have the wiring diagrams for the heavy duty at hand; LJs might be different).
However, your fusable links do not appear to be factory.
Bypassing the blown fusible links ** for diagnosis only ** is possible; fairly easy on the one that connects to the harness by the bolted connector; not so easy with the pluged one. Measuring the voltage is easiest as that also is possible on the plug&socket.
Search the forum for fusible link. There is a member who fabricates replacements. There are also pictures in his post, showing the connectors.
Good Luck Ralf
