Electrical Issue with 1997 FZJ70 (3 Viewers)
Kennesaw, GA
The Cruiser is a 1997 FZJ70.
When I turn the key, nothing comes to life (none of the indicator lights come on and she won't turn over). The head lights work fine.
My thought was battery cables/connections. So I cleaned the battery posts/connections; confirmed that all the fuses were good; confirmed continuity across the fusible links. I replaced the ground cable and the connector to the positive battery post because their condition was suspect.
The lack of life remained after these actions. This clearly is indicating that I am looking in the wrong direction. What am I missing?
Thanks in advance
Hello,
In old age, the contacts in the ignition cylinder and the wiper/indicator switches lose continuity and carbon builds up in their contacts.
Some contacts have carbon build up. Others are fatigued and do not close the circuit. A cleanup and a plier twist can help, respectively, but not for long.
It may be time to replace the ignition cylinder. It is worth checking the ignition circuit and the wipers/lights switch contacts as well. This area is the target of choice of creative alarm installers.
Juan
