I’m in an EMT Class right now so I can’t guve you all the details but if you search you will find this info.
1) you can Hotwire the fuel pump by bypassing the fpr and jumping two of the terminals at that connector. Can’t remember which ones. Do this and attempt to start the car. It should run fine.
2). You can pull your fuel return line off the fuel pressure regulator stick a hose on it and put the other end in a bottle. Crank over and see if you are getting fuel.
This test can be done by just hotwiring thw fuel pump. If desired.
Any check engine codes? Even if the light isn’t on there may be a code stored.
I agree this smells like a fuel problem, but let’s verify and check each box before we jump ahead and potentially miss something.
