I would be very leery of a fan clutch from a parts store. The stock Aisin unit can be refreshed with new fluid, which can be found at a hobby store specializing in RC cars.
You can test to see if it is your clutch by temporarily fixing it into a solid fan drive. Take a hose clamp that is large enough to feed around down between the body of the clutch and the nuts on the hub that hold it to the water pump/pulley. Tighten the hose clamp down so that it doesn't allow the fan to spin free of the pump/pulley. If your issues go away as a result, the clutch is your problem. Having a suitable hose clamp to do this with has saved my ass as a trail fix a couple times.
