What have you all found is the easiest to fit and best working of electric radiator fans from a donor at the junkyard for a 2F engine?
Thanks!
Thanks!
Fits almost perfect across a stock Landcruiser rad too.see http://www.pirate4x4.com and do the Ford Taurus conversion....outta work quite well!
I drilled holes into the stock rad support and used sheet metal screws to hold it to the rad support.Did you just attach with cable ties through the fins or did you need to make special brackets?
Did you need to add a high current relay to power it or was their and existing circuit to tie into?
