DougM,
<"The "hindering airflow at freeway speeds" issue is not resolved on your vehicle because the fan's not on at freeway speeds. The issue is a stationary fan (yours) at freeway speeds hinders full airflow. You have that issue.">
The fan is not stationary at freeway speeds. It free wheels due to the air comming through the radiatior. Full airflow is hindered in the stock configuration as well due to the fact it has to get by the stock fan which the shroud directs it too. The fancllutch is now always engaged.
<" They can be setup to provide more cooling at low engine speeds and because they shut down when not needed they provide a few more HP when they're shut down, and they can be shut off for deep river crossings if needed. That is the sum advantage to them.>"
More cooling at low engine speeds and also low vehicle speeds. This is important to me out wheelin in the middle of summer. Raises the limit before you overheat.
<"Their costs can be significant to get a quality unit, and an electrical failure means the engine is cooked or you sit. If the engine's cooling system was properly engineered in the first place (an 80 for instance) then there's no need for such expense/risk. For my money, even a vehicle with an inadequate cooling system would be resolved a different way - say putting in a larger radiator.>"
I agree, cost can be significant and that was one of the reasons I looked at it a long time. Electrical failure is a possibility and if you have a single fan you will sit. The likelyhood of both fans on a failing dual fan setup is low. If one fails, you simply can wire for the single fan to get you home. You are right about there is no need for the expense/risk but you can say that about the supercharger or just about any other mod if you get down to it. To each his own in that regard. BTW, anyone, who makes a larger radiatior for the 80 that is not custom built?
<"Do some research on them before embarking on what can become a costly way to merely duplicate what you've already got.">
I did my research. I went back and forth on this issue for a looog time. I guess you can say that I did 'merely' duplicate what I've already got. My '86 Celica has dual electric fans that TOYOTA deciced to install at the factory. 280,000 miles and thy still work fine.
In fact TOYOTA installed electric fans in all of their transverse mounted motors. I'm not convinced by your argument that I did the wrong/foolish thing. My experiences tell me the EXACT opposite. I will say this, if you mount the fans through the radiator with those ziptie like straps, you are looking for trouble. A BIG NO! The MUST be mounted where the radiator is mounted to the body.
I'd like to hear what happened to Photoman. I'd also like to see pics of that aux fan that C-Dan was mentioning. (stepping off the soapbox and having a
and sending one
to DougM)
