So I changed my thermostat out the other day. Changed both seals upper and lower for the upper housing. Also changed the temp sending unit. Changed for a few reasons but mostly as it has not been done since I owned it. Cleaned the parts and pretty positive I seated the upper o-ring well. When I yanked off the sending unit plug the inside of the sending unit came with it, so it was clearly very corroded and old. Glad I changed that.
But after refilling the coolant, making sure its not leaking anywhere and running it a few days to try to clear out any air in the lines, the temp it now runs at has changed. It used to run just below the half mark on the gauge, now it reads above half.
In order to be sure my rad cap is working the way it should, I ordered a new one. Should have it today.
I have ran it without the cap on at higher rpms, turned the heat on and off(which is working by the way) a bunch of times, left it parked overnight on a pretty steep grade, nose up. Not positive the air is gone as the top rad hose still feels soft when I squeeze it. Shouldnt it be pretty full and pressurized with coolant?
Anyways, pics below of the new temp it reads... I know, I should use a temp gun to see the temp at the radiator, which I will do today. Other than that, am I missing something, or is this the new temp it runs at? For what its worth, I did see it go up pretty close to the HOT line, but went back down. Its pretty chilly here right now, so i'm sure thats helping to keep it from getting too hot.
