Early 40 brake master used as clutch master in SBC swap pushed the actuation rod all the way out of the slave cylinder. Solutions?
Mopdog
Meridian, ID
Problem is in the title.
Option 1) replace with 1974 Clutch master, braided SS flex line, July 1974 slave, and 11” low diaphragm LUK Clutch. This combo has been working for 27 years on the first clutch.
Option 2) stock Slave and master. Custom centrel force clutch from @FJ40Jim and call it a done with it.
This may also help…
I've been running the mid to later 70's clutch master and slave for decades with my sbc's. Follow the stk 40's adjustments in the fsm. Set you pedal height and adjust accordingly.
I’ve been beaten into submission and given up on the center force clutch. I’ve ordered the mid to late 70’s clutch master and slave. Have the stainless line and the 11” luk flat diaphragm clutch. Now which length release bearing do I use. I have 2 lengths. I’m using the Chevy cast fork and a stock GM cast bell housing iif that makes a difference.
