2ndGenToyotaFan
Moderator
- Joined
- Jan 8, 2006
- Threads
- 264
- Messages
- 9,803
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
If I wanted to control an E-locker with a single double pole double throw switch, would the limit switch in the locker motor stop the motor once it was locked or unlocked? Or does the stock control box get the signal from the limit switch and then cut the power or ground to the motor?
I'd like to do something like this home made diagram, but with a DPDT switch instead of the 2 relays. But I'm afraid that their lock/unlock switch is a momentary type. (On second look it's not, the limit switch cuts the ground to the relays, so they shut off...)
I'm sure I could figure out how to get around the problem, but if anyone else has had any experience with this, I'm all ears!
Edit: On further examination of this wiring diagram it looks like the limit switch only gives a signal back to the control box, it doesn't actually limit the motor internally... Nothing to see here... carry on!
