- Joined
- Jan 8, 2006
- Threads
- 265
- Messages
- 9,823
- Location
- Ashland, OR
- Website
- www.jeffersonstatecruisers.com
Specifically, are the ring and pinion sets the same?
But the elocker is a 30 spline pinion, and the v6 diff is a 28.
Huh. That's odd... I've regeared many TRD e-lockers, have always just bought V6 gear sets, and never had a spline issue.
Ya, that big bearing on the locking cog side is an odd one, I think the only place you can get it is from Toyota. Be VERY careful with the big adjuster on that side, they are impossible to replace if you muck up the threads.
Yes. But the elocker is a 30 spline pinion, and the v6 diff is a 28. Also, the bearing next to the elocker motor is different.
Swap the pinion flange with one off an older diff, and only replace 3 of the 4 bearings, and it will work perfect.
Check out Toyota Gear Installs for more info.
I would think it would be FAR cheaper to throw a 4.30 front diff in your truck
Now I just have to make up my mind...... HeheGood to know its 29 spline not 30. I counted it, and sure enough, your right!
I am running a pair of FJ Cruiser diffs, so it makes sense that I have the 29 spline pinions.
My only wonder I have, is how much heat is being put out. I have never run a new diff before, so this is a first for me. After 5 miles of driving, the entire diff (right on down to the pinion) is really hot. I have a hard time holding my hand on it. When comparing to a '98 4runner, the diff is still cold after the same drive.
Also, with 5.29's and 31's, the truck is SLOWER below 60 mph than with 4.10's.
I'm assuming, the heat is being caused by the break in, and it being slow, is because this diff is still very tight, and when it breaks in, it will be the same as before.
