I don't think the cost/hassle/benefit would ever justify the work but I've occasionally thought about solar powered ventilation for my 80, which unfortunately lives outside.
My rough understanding is that we have an air intake under the dash, for the hvac system, when it's not in recirculation mode. On the other end we have air outlets at the back of the rear sliding windows, through one-way flaps and then the louvered panels. I may be wrong but in my mind those are the only existing air inlets/outlets already in place. Of course there is not filtration, and adding it isn't easy though a few have tried/succeeded to varying degrees.
forum.ih8mud.com
The dream for me would be full time intake air filtration, on par with modern standards, for the HVAC system. Beyond that my wishlist would roughly be:
- an isolated electrical system with a small solar panel, reserve battery and high efficiency fan
- I may kick up panel/battery capacity and use this to power other devices independent of the 80s elec. system
- invisible except for the solar panel from above, though that would be low profile/minimal
- a temp sensor that engages the circulation fan above a certain temp
- an override switch to allow easy manual enabling/disabling of the fan
- could disable/enable the auto, temp sensor operation
- could force-on when camp in the 80, it get's wet inside and needs to dry, etc.
- circuitry to only enable the system when the truck is switched off (auto mode only)
- when enabled and the cabin temp was above a certain point the fan would automatically turn on and pull air through the filter, pushing it out the rear vents
Versions of most of that functionality (minus filtration typically) are available in the RV/Boating world and also show up on delivery vehicles though I am not really familiar with the commercial units. When I was a sailor one of these helped keep my boat fresh during long sitting spells:
West Marine
www.westmarine.com
I've thought of adding something like this to our camper:
Other options:
www.inlad.com
If you weren't afraid to hack into the 80 you could add a ventilation system that was automatic and low maintenance by bolting on a roof-mount ventilator or custom building something that mounts elsewhere. There are floor vent options as well, etc. For some rigs that are heavily camperized, where they cook inside/etc., adding a ventilation fan on the roof could be an asset that makes sense but for a mostly-driver it doesn't seem like a great option in my opinion. I can't see adding holes to my 80 personally, and any useful ventilation added at the windows seems bulky and like a potential security risk.
Tough problem to solve, but fun to think about. I'll follow along with interest in case some good/new ideas show up!
