Thanks for the advice @bloc. I just ordered one of the replacement plugs and will go easy on it removing the old one. I need to look up the torque specs for the front and rear (I can't recall it offhand), but I will check before reinstalling them and will torque to the spec.
I have them handy..
Rear diff drain/fill: 36ft-lb
Front diff drain/fill: 29ft-lb (despite the plugs being two very different sizes)
Transfer case drain/fill: 27ft-lb
If you weren't already aware, even though they will fit the rear axle and transfer plug gaskets are different. Formed steel oring for the rear axle, aluminum crush washer for the transfer case and front diff fill. The front drain will be obvious.
That is awesome..
