Working through a bunch of issues on my 1985 FJ60- just got the wagon about 2 weeks ago, and while the cosmetics are great, the mechanicals side needs a bit of work. New starter (reman OEM), alternator (NOS 55 amp), starter switch, valve cover gasket, new fluids all around, heavy duty battery cables (thanks @Fourrunner), rejet for altitude (has a 38 Weber). FSM OTW.
At some point in the past, the gas tank has been dropped (maybe for the recall) and when it was installed the harness connection for fuel sender was not run back to the middle of the tank. It's tie dup by the LH rear wheel. It appears I can remove cross brace, support tank with floor jack, and then remove straps in rear an lower tank just enough to snake harness through (tank is empty). Anyone have thought against doing this? Anything that might get in the way hose wise? Looks like all of the hose connect right by filler neck.
