The adjustment is on the inside, not out. Having a loose bolt either way its deadly
Mine (2009) does the exact same thing/sound while reversing and turning that your video shows. Anyone have a photo that identifies the lower control arm bolts that need to be tightened to 103 ft/lbs? I don't have the FSM. Thanks for any help.taco47001, you are THE MAN!!
I lifted the truck, grabbed my torque wrench, adjusted to 103 ft/lbs and went after the lower control arm bolts. On the driver side, the rear facing bolt was not tight enough. It took good 3-4 rounds with the wrench to get it to click. The front facing bolt was almost perfect. A bit adjustment.
Did the same thing on the passenger side. One of the bolts was not tight enough.
Test drove the truck - no more clunk!! Gone! Everything is quiet and smooth, like new. Lets hope this clunk does not return again. It's been bothering me for months.
Thank you!!
bottom right is for the lower ball joint/steering knuckle correct? OP reports tightening the control arm got rid of the noiseNah...bottom right. 160.
Hi Jen, i believe the nut and bolt circled in red are the ones you want to check. I'm not sure of the torque specs - 100 vs 103 shouldn't make that much of a difference IMO. just don't let the ones labeled for cam/toe adjustment rotate so that you can keep your alignment.
Whichever they are, I will have them all tightened to those torque numbers. Thanks for the diagram, it will be helpful.bottom right is for the lower ball joint/steering knuckle correct? OP reports tightening the control arm got rid of the noise![]()
Wait....your cam bolts were loose?!?!
