Coolerman
- Joined
- Jan 5, 2004
- Threads
- 142
- Messages
- 6,765
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
Ok I just finished my own saga trying to drill lhrough leaf springs to use the CCOT spring pins.
I am no machinist but have drilled my fair share of holes in all thicknesses of steel. I'll say right now, there is no way that a normal high speed OR a cobalt drill bit will drill through the springs that I have. They are supposed to be from a 1976 FJ40.
No drill press but I did clamp the spring in a vise, used oil and low speed with a brand new split point cobalt bit and a freshly Drill Doctor sharpened and split point high speed steel bit.
In both cases the drill bit would not even get a good bite on the steel. Just to make sure I didn't have two poorly ground bits I used them to drill into a piece of mild steel plate with no problem. Nice curling as the bits cut into it. So I know they are sharpened correctly.
A concrete bit had slightly better luck and I eventually got through one spring. Great 10 minutes to get through ONE! 13 more to go? I don't think so...
