Near as I can figure, it works like this: the provincial act and regs refer to the Motor Vehicle Act (a federal law). Part of the MVA are documents called "Standards" - in the case of lighting, Standard 108. Standard 108 is informed by another document called "Technical Standards Document 108." TSD 108 contains a lot of fine detail about how and where certain lamp is to be mounted, how it is to be aimed, etc. It's quite a technical piece - almost 100 pages long. Finally, the TSD refers to certain SAE standards, which are only available for purchase from SAE, unless you happen to live next to a good academic library at a university with a large engineering program.
So basically, there is no way to "prove" that your lights meet the standards. And even if you did get ahold of the standard, you'd need to get a lab to run the same tests on the lenses, etc., that the manufacturers do. I think I much better approach is to convince the various levels of government that the standards used in other jurisdictions are equal or superior to the DOT/SAE standards. As I mentioned in a previous piece, the Feds are moving in this direction in a limited way with TSD 108.1 (http://www.tc.gc.ca/acts-regulations/GENERAL/m/mvsa/regulations/mvsrg/100/mvsr108_1.html),
but there is more to be done, since this only addresses headlamps.
I'm still digging...man, I wish I'd taken that Government Documents class at library school.
Robin
Robin
I'll scan the artcile and send it to someone to post becasue I still dont know how to post even a picture..? I just tried and it is way over the max size???? 0.5 MB in pdf?? help!
