Door Lock Cylinder Repair?
Yes, I left them a key and they made up the cylinder to fit the key.
Couldn't get my key to go in to the lock this weekend. Looked in the slot and there was some metal thing in the way, deep in the lock. PUlled the lock cylinder out (a 7 min job) and took to my local locksmith. $30 later and it's all fixed. Turns out one of the pins fell into the slot, so he replaced it, and put a new trim ring on it and I'm good to go.
Friendly guy who looks a lot like Billy Gibbon of ZZ Top. I asked about replacement locks. He said "go to a junkyard and pull a used one, or get a new one from the dealer. Bring it in here with your key and I'll re-key it for $25. Whatever you do, don't buy Chinese crap on Ebay. The 30 year old OEM or new stock will last another 30 years when I re-key and service it."
Easy peasy.
I have new keys already, it was damaged from someone trying to break in a few years ago, so the locksmith can supply the whole part new?
Just saw that someone tried to break into mine as well. It looks pretty mangled so I dont think I can repair. Is there a part number for just the cylinder? Any way to buy it? I want to fix asap
Repair and rebuild of the lock cylinders can be done by @ToyotaMatt
I had him do all locks (including my fuel door and lift gate power lock) and the ignition cylinder on my 62 a couple years back, with a new set of keys (including a pair of Euro style keys that are freakin sweet) and he did a great job. Parts for the cylinders are very limited due to long-ceased production, but he can give you details on what exactly he's still able to support. It's not a cheap job, but IMO worth the money.
I bust his chops on a regular basis outside of Mud but the man does have a lot of high quality parts he can provide.
Okay incase anyone else stumbles upon this: @ToyotaMatt doesnt do 100 series locks. However, with a donor door lock cylinder it is really easy to repin and repair your door lock. I bought a random 100 door handle on ebay, swapped over the pins from my lock am finishing up the repair now. I'll start a new thread with a how to later
i am currently only geared up and tooled up for 1997- older FZJ80 / older any VINTAGE TOYOTA .
however , as soon as i have time to bring my Pennsylvania and Maryland state Vehicles ONLY locksmith licenses up to that year span range i will in the coming year ,
i will post a tech thread all about that and this topic .
as i WILL also be code-cutting 100 series key blanks using my SST. NipponDenso computerized machine i have now on hand at the Shkunk -works laboratory using the factory key codes supplied by you my future clients .....
till then .........
all i have going to offer up is :
the WORLDS First and only Exclusive to Erin and My family run online parts store , OEM genuine TOYOTA Parts Japan SPEC . GOLD Plated 100 series KEY
BLANKS !
- i personally plate these to the highest quality possible directly OVER the SOLID NICKLE Alloy oem blanks
YES you can get them code cut and use them as a normal land cruiser anything key for daily use ! :cool:
- NOTE : not real gold ...fyi ....rather YELLOW ZINC Trillium ....
The worlds first 80 series OEM Gold Plated blanks
40 / 60 / 62
Gold plated oem blank
Again the worlds first example run ..
I will be making it a point to contact @cruiserdan and offering them a complete all land cruiser examples of these Gold Plated OEM toyota genuine parts key blanks all made in japan ..
I have a neat shadow box , @cruiseroutfit / Kurt told me a while back,
While the Heritage Museum Lacks floor space , wall space for small “ things “ is abundant for what I hope they would consider displaying in a formal ART WORK format …?
I guess both of them will know since I tagged them now of my wishes to offer up examples of each above ….
:idea:
Kindly
Matt
you might try putting some tri-flow (synthetic lubricant used by bicycle shops, locksmiths etc) into the cylinder. that stuff does miracles. perhaps not this particular miracles but ive had stubborn locks that wouldnt work right for anything until i put some triflow in them, then: problem solved.
one love
jah bill
Worked for me!
