Anyone have a beat on a replacement drivers side door handle for a 94? Mine snapped off today, I love winter.
You could try a salvage yard, mid-90's Camry's used the same handle IIRC.
maybe he's thinking on the inside? weren't those the same? or the inner handle cover or something like that?They did? That's a new one for me. The part numbers certainly aren't the same.
Do you know if any of these are still available from Toyota?The inner handles are also different part numbers. The only thing in that area that was the same was the power window master switch for 91-94
I also have a green 94, Have crack in my handle and have been looking for a replacement for a while. Good luck.Anyone have a beat on a replacement drivers side door handle for a 94? Mine snapped off today, I love winter.
Yes, some colors are still findable, don’t know which/if they are still in production.I also have a green 94, Have crack in my handle and have been looking for a replacement for a while. Good luck.
If you come across someone that has two let me know and i will take the other one.![]()
Hope you enjoying your retirement but for selfish reasons i wish you were notI believe all the rear handles are done. There may be a couple different front colors still available. I no longer have inventory access since I retired so you will have to get your dealer to check for you.
That's an incomplete number. It needs a 2 digit suffix to delineate color.69220-60020 for the green drivers front. Got one last year and Mcgeorge Toyota shows one in stock when you Google the number.
Edit: Didn't see this was for rear
My bad. For the 6m1 the last 2 is G0 (69220-60020-G0) 69220-60020-G0 Genuine Toyota Part - https://www.toyotapartsdeal.com/oem/toyota~handle~assy~front~door~outside~lh~69220-60020-g0.htmlThat's an incomplete number. It needs a 2 digit suffix to delineate color.
