Has a compression test been done?
Fuel pressure test under load?
Sorry, I missed this one. The power button is usually on, but this is a much more dramatic loss of get up an go than that button causes.If it's on/off power wise I'd double check that the throttle position sensor is dialed in per the FSM.
Do you notice a difference if the PWR button for the transmission is on? Mine is always on (but the bulb is burned out) and one time it was off and I thought something was wrong.
My theory on this is that the ECU starts to advance the ignition as RPMs build and the jump from running to running WELL (when it advances the ignition into the "normal" range) feels like a big change from the driver's seat.I guess I’ll let him speak on it but if all issues are sorted, I don’t see why he would mention that above a certain RPM, the power suddenly comes back as if a switch is flipped.
The TPS was new last fall, and I painstakingly adjusted it when the intake and upper plenum were off recently to do injector work. It bench tested correctly, and I set the drop off with a multimeter. I took a lot of time to get it perfect.If it's on/off power wise I'd double check that the throttle position sensor is dialed in per the FSM.
And then we wait..j/kHi all. Thank you so much for all the input, information, ideas and advice.
I've run out of time so I'm going to let this one ride until I get back from a trip. We'll give it some good testing both in transit and offroad.
Everything is running great at the (assumed to be fictional) 24 degrees of advance, despite marks not lining up with the crank pulley notch and timing marks on the block.
I'll keep my new adjustable timing light, 30mm, 12mm and 8 mm sockets handy in my onboard tool kit. I've gotten very quick at removing the distributor after all this practice. If it wasn't for that lower bolt on the distributor cap, I could have it off in a minute flat.
Thanks again, and I will definitely unearth this thread if I figure out what the root cause is. Nobody likes a cliffhanger ending.
First of all, thank you all for the ideas and suggestions.
I'm not in overdrive, and the compression is good.
I agree that tires can have a significant impact, but in this case, since I can completely dial it out with timing adjustments, I am confident that I'm chasing an ignition timing issue.
More as I fine tune.
Like most of the sensors, it is only silly until if fails and you see how much it does.I've replaced my TPS and reset timing to 3 degrees BTDC and all is good with the world.
It is shocking how much impact this silly sensor can have on the way the engine runs.
