- Thread starter
- #21
This is the current location of the lock bolt. It is accelerating amazingly. Timing marks are way off still around 20-ish deg btdc. I suppose another option is the crank pulley is off, but that seems less likely.
All rough running, idling and similar issues have been sorted. Generally speaking, it runs like a top.
I'll mess around with the FPR and resistor tomorrow. I saved both of them. Definitely worth a try.
Hearing @80t0ylc s experience sounds like it very well could be my issue, but I'm definitely up for trying to tackle it multiple ways. Maybe I have a couple of things combining to make it more pronounced.
I still think it's gearing, but it doesn't hurt to make sure all your ducks are in a row. The telltale symptom to me, was when you said that in low range it's smooth from idle up to 3k rpm, and it's not in high range. If there was a fuel or air problem that affects performance/roughness, you'd probably be able to notice it constantly or throughout the performance of the rig - even revving it in the driveway. Timing and distributor efforts are, at 1st you set it per the specs, and then adjust it slightly for the performance you're looking for. Being off a tooth can be compensated with adjustment, as has been mentioned. With the bigger tires, the load on the engine is increased, so in overcoming inertia and until you get momentum working for you, the performance suffers from previous experience with stock tires. By trying the acceleration in low range, you let the gears work for you, although low range is definitely not needed, you've taken the handicap off, that's inflicted on your engine by the larger tires.They have not been removed during my ownership. I also do not see any indication of that in the stack of receipts from prior owners.Have the cams ever been removed? If so I would pull the valve cover to verify the cams are properly set.
It can be tricky to get it right. You are on the right track.View attachment 3608181View attachment 3608182View attachment 3608185
Doesn't seem right.
I need to review the FSM.
No disrespect, but just defending my point of view. Maybe you never had a stock 80 or drove one for a reasonable amount of time. But there is a big difference in lower mph performance with 35's and stock 31's with the non turbo 1FZ. I bought my '94 used in 1998, bone stock with the Michelin LTX 31's. So I know 1st hand the difference in performance, upgrading to 33's and then to 35's. (315/75/16)Also, I don’t agree with gears being your issue.
Mine and a half dozen others I have built have stock gears and 35’s and don’t have your problem. Mine pulls good and strong from a stop with stock gears and 315’s.
Cheers
