Dobinsons MRA - 3-way adjustable struts/shocks w/ resi for 200 Series
crikeymike
ExitOffroad.com - Dobinsons Specialist
Supporting Vendor
Jacksonville Beach, Florida
Website
exitoffroad.com
Hey Everyone. Here is the information for the new Dobinsons MRA 3-way adjustable struts and shocks that are were released in 2020.
MRA59-A688 - 3-way adjustable MRA struts w/resi - For 0-3" Front lift - 66mm body with 22mm shaft - 606mm extended, 438mm compressed
MRA59-A682- 3-way adjustable MRA shocks w/resi - For 0-3" lift - 66mm body with 22mm shaft - 620mm extended, 390mm compressed
Full MRA Suspension Kit - Dobinsons 3-Way Adjustable MRA 200 Series Lift Kit | (2008-2021) 1-2.5" - https://exitoffroad.com/product/dobinsons-200-series-1-5-2-5-mra-lift-kit/
The time has come everyone, time to list the features and details of the long awaited Dobinsons MRA.
Now first up, are they called MRR, MRA, or what?
Well here's the thing - Dobinsons MRR's have been sold out of Australia for many years now, and they have been going thru a constant evolution of upgrades. First they had no valving adjustment at all, and the standard MRR's still do not but they are being phased out, which is also why they weren't ever fully stocked in the USA. So the new 3-way adjustable versions have been nicknamed "MRA" in part numbering for "MRR Adjustable" essentially and so that it's easy to keep track of. So you can call them MRR Adjustable, MRA's, or whatever you like, but for ease of keeping a separation between the regular MRR's and the new adjustable ones, I'll call them MRA's.
3-Way Adjustable - what does that mean?
First, on the external reservoir, it has high speed and low speed compression adjustability. 10 High Speed Compression Adjustments and 20 Low Speed Compression Adjustments.
On struts, the rebound is adjusted at the very top of the strut, via a shaft that goes all the way down inside the strut thru the piston rod. This is done by hand, turning a small knob. On the shocks, the rebound is adjusted at the base of the shock, via a shaft that goes up thru the piston rod. 15 Rebound adjustments. This is done with a small adjuster tool that's basically like a flat head screw driver to reach into the shallow recess to adjust them.
On the reservoir, the high and low speed compression can be adjusted by hand, however the "all-in-one adjuster tool" that comes with the shocks and struts has cut outs to adjust them too if it's hard to reach inside there.
Also, all MRA front struts have a fully threaded body for height adjustment. This isn't included as part of the "3-way" method, but a standard feature of the monotube lineup that Dobinsons has.
More from the engineers:
Built on the Back of the Race Winning Monotube Remote Reservoir (MRR) Shock Absorbers, Dobinsons new range of MRR Adjustable Shock Absorbers combine the best in high performance race-bred Monotube Technology, with an all new 3-way dampening adjustment system to turn your 4×4 into the ultimate off-road machine. Each component of the MRR Shock Absorber has been refined and improved to offer a higher level of ride quality, vehicle control and shock absorber performance.
The new 6063 honed Aluminum reservoir, revised light-weight floating piston, Carbon Fiber / PTFE / Disulphide composite wear band, improved 3 stage sealing system, and the ability to run lower gas pressure with the addition of the reservoir compression adjuster; have combined to provide massive reductions in shock absorber friction, resulting in an improved vehicle ride and dampening performance. The revised sealing design now provides a 3 stage FKM-HNBR shaft seal system that, when combined with the reduced operating frictions, provides a vastly increased service life with reduced wear.
The Micro Polished, Hard Chromed and Heat Treated shock shaft, revised CNC aluminum high flow race piston, and DOM seamless tubing body provides the ultimate in performance and off-road durability. The 3 Way adjustment design reduces the main piston working load, distributing heat more evenly between the main piston and the reservoir piston for reduced operating temperatures, and allows quick and easy damping changes for the ultimate in shock tunability in varying terrain and vehicle loads, to keep you controlled and comfortable.
Attached is the component sheet showing the main features of the MRA's, however here are some quick main points I want to pull out of there.
  • 3mm DOM (steel) thick main body
  • 6061 Aluminum spring seat and reservoir
  • Fully rebuildable design (No set rebuild mileage or timeframe!!)
  • Uses existing range of Dobinsons coils and top mounts
  • Direct bolt on design, no vehicle mods required for strut and shock fitment
  • Maintains rubber lower and upper bushings for maximum NVH dampening
Just be aware - it's best to have a professional with the correct tools on hand to mount reservoir suspension. Drilling, trimming, adding nutserts, and hose routing all need to be taken into consideration for proper resi fitment.
thanks for the update Mike, Nice to have options. I know these have been a big hit with the 4runner guys!
Throwing out some deals here. New 100 series arms just arrived so I figured I'd give free shipping on those and some others too
@stevopike yes, there is a black 200 I saw at their booth at expo had this system... not sure who.. seems like they has Virginia plates,,
Perhaps the UCA's are in my future. I've got squeaky SPC's after about 50k and I'm debating an attempt to stuff factory bushings in them or replace them. Come to think of it, may be time for shock replacement as well since my OME's have the same miles on them. FWIW, I have a buddy who installed the Dobinson MRR's on his TX Baja Tacoma in place of the factory TRD (Bilsteins) and loves them. Thanks for posting.........good info.
Oh wow, you reckon the bushings in your SPC are gone already? I thought they had solved their bushing problems. If factory bushings would fit in there, that would be a good long-lasting option.
I am bumping this out of curiosity as to if anyone on here is running these. They look so good.
double bump, these are highest on my radar now!!
I'd love more GX perspectives too!
My thinks (with KDSS) .. Set for 2" front, with 1/4" spacers (ergo 2.5 front lift to maximize articulation w/o too much preload)), 1.75-2" rear (depending on options, like adjustable coil conversions (IM has one that can afford some lift of coil)) and add a KDSS drop kit with panhard bar to maximize articulation gains of KDSS while getting suspension lift and longer travel...
I would LOVE your thoughts @crikeymike .... in fact I'll probably start a PM conversation with you to discuss these ideas... 🤔
*EDIT* In hindsight, sorry for bumping info for 120 in a 200 thread, I was life-avoiding, mud-browsing, impulse-posting on a topic of interest ;)
I'm sure ya'll understand ;)
Dobinsons sale starts Monday the 8th. Click here for full details:
Hi all,
I recently installed these in my 200 series. They are excellent in how they look as well as the adjustments you can make. I was wondering if anyone has installed them and has some experience in what a good adjustment is for the 200 series LS, HS and rebound. I'm still fiddling but don't do enough driving to adjust. I want close to a standard feel when highway driving and a good all round offroad adjustment. Any suggestions?
Hi all,
Here are Dobinsons general setting suggestions for the 200 series. Great starting point.
Hey Mike! I noticed the collapsed and extended lengths for the rear shock are different in this post versus the linked sale page on your website. Could you please clarify which are correct? Thanks
Just updated this old thread with the correct numbers. Originally we were told he length specs would be the same as the existing shocks, but they weren't once they finally came out, by a few mm here and there.
