So i am starting the install tonight. All the parts are here for a full replacement. I got under the car and was looking at the sway bar. Will I need to remove sway bar links on both sides to move it up and out of the way? Or will I be able to pull the coilover out by just disconnecting one side? I haven't seen any instructions in the forums about the sway bar.
Just cut across the bottom edge of the nut above the washer.So I'm all in except for the rear shocks. s*** ain't coming off. The top nut is not budging even soaking with PB blaster for two days. Pipewrench etc... I was going to cut as a last resort . Where did you cut the shock with the sawzall?
Nice riding suspension by the way. Here is what it looks like 1.75 up front 1.5 rear . It actually moved it up 2" inches and 1.95" rear .
Slick ride. What sliders did you put on?
Looks good what size tires are those?
